Conversion Job
Joe Grosso
Joe Grosso Member Posts: 307
Installed 19 series 7 section hot water boiler with two 330 fuel oil tanks in a very large christian brothers home.I do not want to do this type of work on every job.These sections are HEAVY.
P.S. Yes we removed a ideal gas boiler and replaced it with this oil beauty :)
  • jerryb
    jerryb Member Posts: 113
    Nice looking job,be proud.
  • Frank_4
    Frank_4 Member Posts: 5
    You cold have put it in with a gas burner and call it a gas clean buty :-)
    Clean looking job. Is that gas hot water tank still being use? I cant see if it is conect to the chemney. Or is it going to be replace by that tankless
    coil in the boiller?
    The only thing I can comment is that "minimum water line" mark on the boiler is for steam apliquation. For hot water the low water cut off is normaly instal above the boiler.
    Francois.
  • Frank_4
    Clean looking job. Is that gas hot water tank still being use? I cant see if it is conect to the chimney. Or is it going to be replace by that tankless
    Francois.
  • Bill_3
    Bill_3 Member Posts: 34
    Tanks
    Is that one feed going into two tanks across the top. The Vent on each end. Do both tanks feed that filter at the same time.
  • Joe Grosso
    Bill
    Yes both tanks are feeding that filter at the outlet of the fuel tanks.Also have a spin on at the burner
  • todd s
    todd s Member Posts: 212
    Oil lines
    Nice job Joe, I like all the valves at the tanks ball valves for service firomatic and osv for safety. What brand tank guage is that?
  • Joe Grosso
    Oil Gauge
    That is roths brand.Real nice little gauge much easier to install than scully or king and takes up hardly any room in the truck.All my tank installs get a osv and a filter at the tank and then a filter at the burner.
