drip and return
anthony_2
Member Posts: 1
In my steam system, I have a dry return that runs midway along the wall in my basement. Once it gets into the boiler room, it drops to the floor and runs around a built in wall closet and into the boiler. The drips from the upper floors seem to tie into the return at the floor. I seem to have some water hammering from the riser the riser of the same drip I mentioned above. It usually happens at the end of the cycle when the boiler turns off and the system is cooling down. I have flushed the returns till steam comes out (does that mean they are completely clear?) thinking that might be the problem but I still seam to have the clanking. Help would be appreciated, I am a do it yourselfer who can pretty much tackle anything with some research. Thanks in advance for any response.
Anthony
Anthony
That dry return
was probably a wet return with the original boiler. I'll bet you have steam hitting water in that horizontal pipe, which would cause banging.
The solution is to lower the pipe so it is below the boiler's water line.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
