gas boiler with domestic coil
Jody M.
Member Posts: 5
I saw a new boiler from Embassy Industries called the Ambasador i think. Believe it comes in propane and natural gas. Does heat and hot water
DOMESTIC COIL IN GAS BOILER
IS THERE ANY COMPANY OUT THERE THAT MAKES A GAS FIRED DIRECT
VENT BOILER WITH A DOMESTIC COIL FOR HOT WATER?
there are many..
Weil-mclain makes the CGt. Laars makes the Endurance, NY thermal makes the Trinty for starters...kpc0 -
We used a Peerless series 61
in a house with no room for a separate heater . The coil is doing fine for the family of 4 . We used a 5 GPM coil . We had to change it to maintain temperature - it comes as a cold start boiler .0 -
Boiler with coil
Slant Fins galaxy series GXH models come with an optional tankless heater. I cant imagine why anyone would want one though, they are not energy efficient and dont provide much hot water. If you can use a direct vent model you may want to try the Teledyne Laars Endurance or the Burnham Minuteman. good luck.0
- 167 Indoor-Air Quality
