gas boiler with domestic coil
Jody M.
Jody M. Member Posts: 5
I saw a new boiler from Embassy Industries called the Ambasador i think. Believe it comes in propane and natural gas. Does heat and hot water
  • D COFFEY
    D COFFEY Member Posts: 3
    DOMESTIC COIL IN GAS BOILER
    IS THERE ANY COMPANY OUT THERE THAT MAKES A GAS FIRED DIRECT
    VENT BOILER WITH A DOMESTIC COIL FOR HOT WATER?
  • kevin
    kevin Member Posts: 420
    there are many..
    Weil-mclain makes the CGt. Laars makes the Endurance, NY thermal makes the Trinty for starters...kpc
  • We used a Peerless series 61
    in a house with no room for a separate heater . The coil is doing fine for the family of 4 . We used a 5 GPM coil . We had to change it to maintain temperature - it comes as a cold start boiler .
  • prisco panza
    prisco panza Member Posts: 6
    Boiler with coil
    Slant Fins galaxy series GXH models come with an optional tankless heater. I cant imagine why anyone would want one though, they are not energy efficient and dont provide much hot water. If you can use a direct vent model you may want to try the Teledyne Laars Endurance or the Burnham Minuteman. good luck.
