PEX tubing with O2 Barrier??
anthony_7
Member Posts: 72
I have been reading about using the o2 barrier pex. I am looking to cover about 550sq ft with a mud job.
Should I use 1/2 pex O2 and how far apart should I space??
Also how much of a run till I start with another. I hear max 300 ft of tubing as a rule??
Thanks
Thanks
Please..
Get design assistance. Any radiant job needs to start with a heatloss, have controls and outputs designed and the results applied as tube spacing, insulation requirements, flow rates and fluid temperatures. The process is fairly simple but you can't just plunk in some tube and expect to have any reasonable results. Try "find a contractor" to the left and rent some talent. Enjoy.....Dan
pro's
try wirsbo.com0
