1910 boiler pix
John Mills_3
John Mills_3 Member Posts: 221
Gravity hot water, found in an old double in St. Paul. Still purring along...
    Steamhead Member Posts: 18,218
    Those are \"Ideal Arco Round Boilers\"
    probably installed in the mid 1920s- they look a bit newer than 1910. If I know the model numbers I can look them up. I wonder if they were using tank-in-basement systems that early, or if they were added later.
    You're right, they last a long time.... but they're probably running about 40% efficiency with those oil burners, according to one of my Dead Men's Books.
    You could probably cut their oil consumption in half by replacing them.
    Consulting
  • John@Reliable
    John@Reliable Member Posts: 379
    Around here we call then
    snowman(when still covered with you know what) I guess you have tinmen there!
  • J.C.A.
    J.C.A. Member Posts: 349
    John,
    Up until about 14 (or so)years ago, I had a customer with the same set up with one exception . He had the boiler on the left valved off but still ready to ....WITH COAL!!
    Still had the rotary Minneapolis/Honeywell chains and switches hooked to a thermostat in the kitchen . When the power went out , it was just a matter of stoking the old beast and opening the damper to the desired setting and he had heat while everyone else went without . Yankees is what they called them around here ,smart M/F's is a better description of some of the old timers I had for customers when starting.Oh yeah...A rather large gravity hot water tank piped off the side (about 50 or so gallon upright galvenized) could be used for a "tempering tank "when the oil was up , but provided hot water by throwing a couple valves in the event of a power failure . Not the highest recovery rate but he had hot water just the same . Chris.
