Commercial Remote Thermostat - which is best?
Steve R.
Member Posts: 5
Thanks Guys,
We're going to go with the Honeywell
Steve.
Steve.
Commercial Remote Thermostat - Which is best?
We have a public restroom that gets a lot of use and abuse. Does anybody have a good remote thermostat that they like?
Thanks,
Steve R.0 -
Remote sensor commercial stat
You could try the T7300...it has a remote sensor, the stat is located in another area, where it is secure. It might be a bit of overkill, though for that application. We also have metal or plastic thermostat guards, and our newer programmables have range stops that prevent any changes above or below pre-programmed temperature limits. All available from your Honeywell distributor, or click on "Find a Contractor". Hope this is useful.0 -
Remote thermostat
If you have a drop ceiling put one above it.I have done this in comm. & apt. buildings.Just mount a T87 like normal(level)0 -
remote stats
there are several t-stats available now that have remote sensors available, but you have the same problem, if they can break the stat they can break the sensor. in high damage area's we use "prison grade" flat sensors. they are esentially a flat stainless cover plate with the sensor on the back. the last batch we got actally came from tek mar and I used them in place of the room temp units. (we put them in the space and remote mounted the rtu's in the boiler rm next to the controller. Paul.0 -
As Bill said..
use the T7300 with the remote sensor and a steel cover for it.
Those suckers just plain WORK!!!!!
Have used ton of them and they are worth every penny.
Floyd0 -
Thanks!
Thanks for using our products, Floyd!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
