Carrier 58 wav control problem
Bruce Richmond
Member Posts: 1
I have a problem with the control unit on a Carrier 58 wav. Does anybody have access to a carrier service bulletin smb 96-0023?
What exactly
Is the WAV. I've installed some Carrier furnaces. MCA's MVP's etc. Had gobs of circuit board failures. What is yours doing?
58wav
It is carrier product designation,the 58wav is a 8000 high
efficiency upflow furnace.0 -
Carrier 58WAV
Bruce if you have a fax # I will send you a copy of 96-0023.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
