The circle of heat hr
Cosmo
Member Posts: 159
we think, everytime I see something I always try to figure how it was done. Thanks for bringing back to earth....
Cosmo
Cosmo
unbroken
My primary loop with V/S injection from a wood boiler/ buffer. Back up MZ power. PAB by Wirsbo, Weil, and Kitec.
hot rod
Help me out
What is the equipment in the top dead center of your loop?0 -
HR, That's
beautiful! And I know it works as well as it looks.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
TDC
is a Sparco air purger with a unistrut band around it to fasten it to the wall. The 1/2 Weil pex goes down to the floor mount expansion tank.
hot rod
Too much........
Time on your hands Hot Rod. Too much time. I wonder if you have a job or your hobby is artistic hydronics instead of bird watching like Dan's.
How
How did you get the primary pipe circle perfect? Only thing I can think of is you may have cut a circular piece of plywood to use as a jig to bend k-copper around....
It is beautiful man....
keep it up,
Cosmo0 -
A really cheap trick!
It is just 1 loop off a coil of 1-1/4" K copper coil
I customizied some angle pump flanges using the new Blockade solder from JW Harris.
hot rod
