Up on blocks ...
Frank_3
Frank_3 Member Posts: 112
I notice that some folks put boilers up on blocks of some sort, and others don't. What is the purpose/benefit of raising the boiler those few inches? Is there some code requirement, and if so what's the required height of the blocks? (And which code?)
  • John@Reliable
    John@Reliable Member Posts: 379
    Why on blocks?
    #1 Flood - #2 Can make piping easier - #3 ? to early to think on a Sunday
  • Gary Fereday
    Gary Fereday Member Posts: 427
    wrastleing
    I like boilers up where you do not have to wrastle the ground to service them. a 2 ft. high stand is made of iron angle and bolted to the floor,(The expansion tank goes under the boiler). This was accomplished for a Slant Fin mounted in a garage. Have also seen it done in a basement. Nice to walk up to them. Up oof the floor carring dust. easy to service, cleaner looking installation. Anyway bigugh
  • Bill_14
    Bill_14 Member Posts: 345
    Housekeeping Pads
    Most commercial projects require the boiler room equipment that sets on the floor to have a 4" high or 6" high concrete "housekeeping pad" under such equipment.
    This makes for a neat looking installation, keeps water on the floor away from the equipment, keeps debris from accumulating under the equipment, etc.
    The same thinking would apply to residential installations...just looks better and more professional than concrete blocks or nothing at all...in my opinion.
    Bill Russell
  • Floyd
    Floyd Member Posts: 429
    Whether it's dirt floor...
    or concrete I just feel that it helps to keep the condensation out
    from under the boiler....you have a large temp. difference between
    teh boiler block and the cool floor... often in a basement that has a bunch
    of moisture.
    Then add as has been mentioned.... it makes piping and servicing easier,
    and makes the job look neater.
    Floyd
  • Steam or Hot Water
    If you're talking about steam boilers, it could be that the installer wanted to keep the wet returns wet; if you drop a replacement boiler too low, you run the risk of dropping the water level and loosing a water seal. Steam can back up into the mains and cause water hammer.
  • John (jcg)
    John (jcg) Member Posts: 43
    Big plus
    On a lot of American made units the insulation is in the jacket so the bottom of the boiler is exposed. Putting the boiler up on blocks helps keep the concrete floor from sucking heat out of the boiler.
    jcg
