another don vito query
leo g_8
Member Posts: 2
@ our local viessmann place said that when using the don vito for indirect heating, you have to upsize the tank because the pump within the unit is a 240 volt model that has been derated for N.A.
I was wondering if anyone out there has run the indirect off a seperate circ (like pri/sec) or ran 240 to the unit? or any other stratagem?
leo g
leo g
Just Brainstorming
A Transformer could be used (ordered, made) to get the voltage correct. It may not be to costly, if the load for it were small. Mounted nearby and painted to match it would look the part. Just an idea. bigugh0
- 167 Indoor-Air Quality
