what's this??
what this register set-up used for?? the old gravity coal furnace throughout the first and second floor!!
  • a blast from the past
    found this on the second floor bath!!
  • did i mention this has.......
    a steam heating system!!
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Their may be
    some steel fin tube or a convector within the wall. That is, if their is a steam system or HW system.
  • Paul Pollets
    Now I'd bet...
    that you've got some concealed supplemental steam coils or fintube convector behind the walls.
  • lots of rads
    under covers, but did not have time to pull anything apart or get really nosy!!
    Steamhead Member Posts: 18,213
    Murph, those are recessed convectors
    I'll bet theyre either Trane or Herman-Nelson, or maybe Webster. I have the Trane and H-N books that cover their early convectors- let me know if you need any info from them.
    This is probably a Vapor system of some sort- I didn't see anything definite in the boiler room pic to say for sure, but Vapor was much more common with convectors than one-pipe steam was. I know Trane used cast-in orifices in some of their convectors, not sure about H-N or Webster. On the Wall some time ago there was a thread in which those built-in orifices bit someone who made the mistake of converting them to hot water- the orifices cause some very loud whistling!
    And by the way, is that an old Ideal gas boiler sitting next to an Ideal smokeless coal boiler?
    Consulting
  • here steamhead
    some more pics of the piping and traps!!
    Looks like a Webster Vapor System
    You might even find those old Webster Sylphon radiator traps! You might also find trap housings cast integral with the convector elements- be real careful with these, they're easy to break when trying to open them to replace the elements.
    The Vent Trap has a vacuum check mounted on top. I'd remove that- the short firing cycles of oil or gas can cause problems with steam distribution if you try to run vacuum.
    I have the catalogs for both the Ideal gas boiler and the National Jacketed coal boiler- tell me what model numbers they are and I'll post the pages.
    Consulting
  • i seen that trap
    > elements.
    > I
    > pages.
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 157&Step=30"_To Learn More About This Contractor,
    > Contractor"_/A_
  • i seen that trap
    on the third floor somewhere, i think !! i was just there antique(ing) and after the BS session i was getting in a hurry!!
    going back today to pick-up a couple things and see if we can get that pic, frank i was thinking of you when i got in there to look!!
  • small 1/2 \" line runs bak
    > elements.
    > I
    > pages.
    > _A
    > Contractor"_/A_
    to the returns ,had not alot of time point and clik, but oh well here tis!!
    That's an ordinary Vapor radiator trap
    piped a little differently, but it does the same job- to pass air and condensate into the dry return, while blocking steam.
    You've got a heating museum there!
    Consulting
