Glenn Stanton , we just got our 1st Burnham V8s
will be a 5 section steamer. Cant wait to try em out . One question , and this might sound like I am a really bad nitpicker , but any chance of changing the bolts that hold the burner flange on , to something like studs and nuts , like Peerless uses ? The Riello burner comes with that crappy , brittle flange gasket that has no perforated holes . And we wind up trying to cut the holes with a knife and break it alot . If it came with studs we can line it up and actually punch it into place using the studs in the burner plate . Thanks for any help Glenn .
Ron,
Are you using the generic "Red" Riello burner or the one that is supplied by us for these boilers. The one we supply would be "Sherpa Blue". Let me know. I have also e-mailed you regarding this Ron.
Glenn0
