Ideal Slyphon
Al in Portland
Member Posts: 4
I saw an "Ideal Sylphon" on a hot water gravity boiler today. It went from a supply off the boiler and discharged down as a return. Some sort of bypass. What is it, and how does it work?
Is this it?
Retired and loving it.0 -
Is this it?
Thanks
That's it Dan. I guess if you need to know something about boilers, THERE'S ONLY ONE GUY TO ASK. By the way Dan, if you need one, I might be able to help.0 -
The Bethpage Heating Museum
would give one of those beauties a fine home! Thanks, Al.Retired and loving it.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
