c-values for copper and PEX
David_2
Member Posts: 6
I'm trying to run through some calculations based on the equations is Siegenthaler's Moder Hydronic Heating and I can't find a table of constants for smaller sized tubing typical in radiant floor heating. His table on pg 139 only goes down to 1/2" copper. I assume that PEX would have about the same constants for a given inside diameter of copper. Am I right on that? Does anyone know where to find the constant for 3/8" copper/1/2" PEX?
Thanks,
David
Thanks,
David
books & moore!
Dan has the "rad pad" that showes just all of what you are asking.0 -
\"rad pad\"
I'm looking but I'm not sure I'm seeing. "rad pad" in books?0 -
Now I see it!
The RadPad. I'll order one today. Anyone want to slip me the number for 1/2" PEX so I can finish my calucalations today?0
- 167 Indoor-Air Quality
