Dirty water
ross swazy
Member Posts: 7
Dan Holohan suggests that if there is too much sediment in the water, in addition to cleaning the strainer to protect the pump, the system itself should be cleaned with trisodium solphate.
Can someone tell me how this is done? What is the correct quantity of solphate to be used? How is it fed into the system? How long does it have to stay there? Does the system have to go through one or more heating cycles before the solphate is removed? Does the system have to be rinsed after the treatment with the solphate and before being refilled with fresh water and the oxigen scavenger?
Are there any precautionary measures to be taken before introducing the trisodium solphate in the system to avoid possible damages to some components of the system?
In other words guys, I have never done it and so please tell me everything you think I should know.
Hey Ross!! any relation to Patrick?????????
They say I used to look like him when I was young, trim, and had hair....aznyway, you really should get a professional in for this - trust me...Go to FIND A CONTRACTOR at this site...good luck Mad Dog
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
