teletemp2010 thermostat
steve z.
Member Posts: 11
i have a teletemp 2010 thermostat in my camp that has a modem in it. i call up and can turn my heat up/down during the winter. i need to buy another one as my camp was hit by lightning and fried it. the company teletemp or teletherm in california seems to be out of business. need to find a new one or replacement style unit.
thanks
steve z
thanks
steve z
Communicating thermostats
Honeywell has two options, either our networked zoning system, which works with either forced air or hydronic systems, and with the optional telephone access module, you can call from any touch-tone phone to check status or change temperatures. It will dial out an alarm to you, your heating/cooling contractor or your security company. The PC8900 also offers the communication module, but can't do the zoning function of the Networked system. Go to www.honeywell.com/yourhome/ to see more info. This is available only through your heating & cooling contractor; use the "Find a Contractor" feature on "The Wall" to find one near you.0
- 167 Indoor-Air Quality
