Recommendation: Replace HydroPulse Boiler
William Clark
Member Posts: 1
Hi All,
I'm replacing my 100,000 BTU HydoPulse Boiler. My local
place recommends a Munchkin. Are there any other boilers
I should consider?
My current system feeds 96 Feet of baseboard on 3 zones and
a water tank on a forth zone. It uses LP. It lives in my
furnace room. I am interested in reliablity and it would be
nice if it was efficient also.
Many thanks for any thoughts.
regards,
billc
I should consider?
regards,
billc
Weil McClain GV
Eff., cast iron, and most of all PROVEN reliability!!!!
Won't break the bank either.
Floyd0 -
Are you commited
to using the current PVC flue? If so your choices are limited. Munchkin, Polaris and a few others are able to vent in PVC.
If not there are tons of options in the cast iron sector.
hot rod
No reason to
go crazy on a sales pitch, but if you are interested in doing some research on your own, goto viessmann.com and see what is offered.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
