Circulators Push or Pull
heatboy
heatboy Member Posts: 1,468
> What is the current feeling on the "best" way to <BR>
> install heating circulators? On the Feed side or <BR>
> the Return side of a loop system. <BR>
> <BR>
> I am <BR>
> talking about a Hot water Heating System (loop <BR>
> system using zone valves ). There seems to be <BR>
> professionals on both sides of the issue but none <BR>
> can give a good reason for their choice. I would <BR>
> welcome a discussion about this issue. Is it <BR>
> becuase of pressure in the boiler (good or bad), <BR>
> air getting into the system (from where?) and / <BR>
> or cooler temps on the return side ? <BR>
<BR>
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • PipeBender
    PipeBender Member Posts: 3
    What is the current feeling on the "best" way to install heating circulators? On the Feed side or the Return side of a loop system.
    I am talking about a Hot water Heating System (loop system using zone valves ). There seems to be professionals on both sides of the issue but none can give a good reason for their choice. I would welcome a discussion about this issue. Is it becuase of pressure in the boiler (good or bad), air getting into the system (from where?) and / or cooler temps on the return side ?
  • it aids in air removal
    to put the circulator downstream of the expansion tank on the supply piping. Dan has an excellent book on this subject.its called ''pumping away''. its in the BOOKS and MORE section of this web site.
  • Bill NTSG
    Bill NTSG Member Posts: 321
    Try this
    > I am
    book. I have been using the pump away method for over 10 yrs with excellent results. The only time I don't is when I am told not to by my boss. Go figure
  • eleft_4
    eleft_4 Member Posts: 509
    Push or Pull
    Hope these pic's help. Methods used from this book.
    http://www.heatinghelp.com/shopcart/product.cfm?category=2-2
    al
  • definitely push
    i put pumps on the return for years. then a friend of mine talked me into pumping away. the first job i tried it on was a 4 story bldg. and i haven't been back in 5 years yet to purge it. pumping away has worked for me on many jobs since then. i strongly recommend it. bob
  • nick z.
    nick z. Member Posts: 157
    Pumping away
    is a very good book. and will make you understand how press. diff. moves the water,and what it does to the air in the system.
  • PipeBender
    Some Manf. Feedback
    Here is what I got from Taco.
    In a low head residential system, circulator location is not critical. If you were to purchase a packaged boiler most will have the pump on the return side. It would be very rare to have any issues caused by pump location on a low head system. The correct location (and our recommendation) is on the supply side of the system, pumping away from the expansion tank. This should eliminate any possible issues. If you have any questions please feel free to contact us anytime.
    Regards,
    Rick Brindamour
    Technical Services
    401-942-8000 Ext. 275
