twin coil DHW heaters
AKO
Member Posts: 34
Looking to replace existing Vaughn indirect solar DHW heater with electric assist with a heater that has a second indirect coil (to drive from a boiler) instead of the electric.
I know of only the Viessmann Vitocell B-300. Anyone know of any other alternatives?
HTP Superstor
has them available in their catalog. Also Crown will build them to your spec with two coils.
hot rodBob "hot rod" Rohr
another source
try www.metalpres.ca Dan
Dual coil indirects
See www.htproducts.com go to ultra see SSU C series and you will find the specification sheets for sizing and related data.0
