apollo wall boiler?
ed_7
Member Posts: 1
has any one seen a apollo wall hung boiler? i have come across one in a condo project thats about 10 years old. the unit needs to be canged, its in a closet 2 feet deep,direct vent to outside. thinking of using a rinnai continuum as the new heat system, have used them as hot water heaters and they work very well. any input will be helpfull. thanks in advance. ed
I've only seen one
Apollo and it had an input of 62,5000 BTU; a Rinnai may be too big. What is it doing: radiant? hydroair? radiators?
You might want to consider a Weil-McLain AHE wall-mounted boiler that's set up for hydronic heating; 2 models AHE-45 (45,000 input) and AHE-60 (60,000 input).
Alan
You could
also install a Munchkin.
- 167 Indoor-Air Quality
