sq ft heating surface from coils in air handling system
Lawrie bruton
Member Posts: 3
have the following problem?
replacing boiler in old building We have gone around the building and sized all the Rad's
The building has a air system with 2 steam coils. no information onthe unit.
the blower motor on the unit is 3HP
The unit is connected with a mixed air section set 55 deg F
Coil sizes are 66" X 17" 2 of
Any Ideas how to come up with the EDR #
Thanks for any help you can give
Lawrie.
Lawrie.
wild **** guess: 219,680 BTU/hr
from the trane TOPS selection program0
