How the heck do you post pics here now? - Mad Dog
Mad Dog
Member Posts: 2,595
I'm havin' big trouble can anyone walk me thru it. Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
you ole' dogg
just hit the attachments button on the bottom, then browse to the folder where your pic is. piont the pic then press add , you can post one pic then add a few links to more of them. when you hit ok then it will throw you back to your post with the attch. then click on the one you want to open, just remember no nude or offending photos or i will be forced to use my "delete" button
sheriff murph' (SOS)0 -
Pics
You have to click on the "Attachments" tab.
Then when you have the pic you want, click "Add".
You will also have the option of having the pic appear with your post.
Mark H0 -
Nudes ain't my style M urcph
but I can't promise not to offend, but I will try Mad Dog
you should have
> Mad Dog
> _A
> 210&Step=30"_To Learn More About This Contractor,
> Contractor"_/A_
you should have
an edit button on your posts also in case you have second thoughts on some of your post, or in the spelling of names0 -
Pics
Ok did what you said, but pic is not appearing. Did not see an option button before I posted that saqid I ha d a choice of posting pic with post or not
the part
of hit attch then browse, hit open ,then add the pic, will move into box ,find another then move into box till box is full or have the ones you want0 -
the part/ part two edit tryout
of hit attch then browse, hit open ,then add the pic, will move into box ,find another then move into box till box is full or have the ones you want, then hit ok
att-browse-open-add-/browse-open-add/-ok-check one
you may have to wait a few seconds for it to add it , before clicking ok0 -
Not moving into box
what should it say in the box?????
Try this
Hire a moving company. :>)
Hahahahahahahhahahahahah
hahahahahahahhahahahahhahahahahahahahhahahahahahahahahahahahahahahhahahahah!!!!!!!!!
:)2 points for the sunshine radiant man!0 -
Testing in floor pic
Colin
How about a description of the install.I'm seeing a shell and tube HX for pool water and I'm guessing some radiant with kitec.Very nice install.What is the boiler?
cheese0 -
Boiler pic
Thanks for the thumbs up!0 -
Boiler pic
Thanks for the thumbs up.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
