Watts \"EZ solder\" valves. Brian W.
Brian (Tankless) Wood
Member Posts: 222
Happy 4th all.
At another site, I saw mention of a Watts "EZ solder" valve.
According to the man's description, it is designed to minimise or eliminate heat damage to the seals while soldering. I went to Watts site, but couldn't find the valve.
Anyone heard of it, or used it.
I'm off to cremate some yardbird then watch the fireworks. Have a safe day out there.
All the best from Brian & Autumn in Swampland.
EZ sweat
For more information than you probably want,see
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=/netahtml/search-bool.html&r=1&f=G&l=50&co1=AND&d=ft00&s1=''6,019,349''.WKU.&OS=PN/"6,019,349"&RS=PN/"6,019,349"
click on the "images" button at the top or bottom of the page to see the drawings.
- 167 Indoor-Air Quality
