VS injection pumping made easy hr
hr
Member Posts: 6,106
Doesn't get any easier than this. Intergal check in the pump, exercises every 3 days for 10 seconds, post purge for 20 seconds.
Many will reconize the control components :)
Very reasonably priced, I might add. Nice work Grundfos/ tekmar
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
Where did you get it? Mark H
I want one.... or two or three...
Mark H0 -
HR VSPumping made easie(r)
We carry a pump panel out of Canada (HPS) that incorporates the Grundfos injection pump with zone pumps (up to four). Sweet0 -
We carry a pump panel out of Canada (HPS) that incorporates the Grundfos injection pump with zone pumps (up to four). Sweet.
http://www.hpscontrols.com/
Check it out.
Michael0 -
panel
Not exactly injection is it?0 -
Mark- you canget
the pump at any Grundfos wholesaler. It's called the Miximizer.
Email me if I can be of any further help.
Rich0 -
Injection pump panel
What part of this panel is not injection?
Michael0 -
I apologize
the pictures on the web site show a 3 way mix valve. The new panels have the grundfos mixmizer system. If you would like I can send you a digital picture of what one looks like installed.
Michael0 -
HPS Control Panel
Here is the picture of the Injection HPS Control Panel installed in our showroom.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
