Some new sticker ideas hr
hr
Member Posts: 6,106
Hot off the press. I find sometimes homeowners get confused regarding wall stats. I had these printed to label the Danfoss MTD and the new tekmar thermostats I have been using. Elderly folks sometimes forget or get confused when trying to control their HVAC and radiant systems.
I use a manual 12 timer for a snowmelt overide on the tekmar controls. A label reminds users of this feature.
The glycol stickers notify others that may work on my systems the presence of anti freeze solutions in the system, before they drain or add to a system. Twenty some dollars bought me these sheets of stickers.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
stickers
HR the Glycol stickers really hit the spot. Do you make them up or do you get them from DOW. Really good idea, I think I saw some that had your name on them.
Scott
Sign Pro
makes them for me. I fax a hand drawing, size and color choices over and pick them up a couple days later. I left room to magic marker in a date of inital fill also.
These little sign companies are everywhere. Anything from a small sticker like this to the entire side of a semi trailer. All computer generated, wild stuff.
hr
