Part identification
Looking To replace this but I'm not sure what exactly it's called. Its on a friend's older home with a mono flow system.
it is a radiator valve with a screwdriver slot to operate it. it is to isolate the radiator so you can remove it without draining the system (if both valves hold).
it would be easier to rebuild it by cleaning up the stem, replacing the packing, replacing the washer, and getting a new handle than to replace it. if you replace it you will have to cut the spud out of the radiator and install the spud that comes with the new valve. you also probably will need to deal with the width of the valve being different.
those may be plug type valves that use a ground plug to seal instead of a washer.
The one with the bare stem is a hot water angle radiator valve, the handle is just missing. The fitting on the other end looks like a lockshield, if that cap unscrews and there's a stem under it, that's what it is (it's set once to balance the radiator, not used as a shutoff).
New valves come with their own union nut and tailpiece, so plan on getting the old tailpiece out of the radiator too, that's usually the stubborn part. Check the pipe size and whether the copper is sweated or threaded into the old valve before you order.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
