Boiler pressure too high
I have been reading some stories recently of boiler pressure being too high. In the last forty plus years I can think of a few occasions that were a little scary. I suppose others may have better stories than mine.
Dad visited the homeowners in their new to them 1920's home in Maplewood NJ. The family just moved in and decided to get an estimate on replacing the original steam boiler. The boiler was originally coal fired, then converted to oil, then converted to natural gas. All of these conversions took place before these people moved in (1988). The boiler was a snowman type with the horizontal cast iron sections, stacked like pancakes. Dad mailed the estimate for the new Weil McLain EG steam boiler in mid October. The family approved the proposal and we agreed to do the work between Christmas and New Years. Dad mentioned that the boiler was on "borrowed time." He warned the people to keep a close eye on the water level in the gauge glass and make sure the thermostat setting was not raised or lowered too much. "Old Betsy" was leaking a little water and he thought temperature swings may make the leak worse.
The family left NJ Thanksgiving weekend. While they were visiting relatives out of state, the boiler kept percolating (or so we thought). When they arrived home Sunday evening from their trip there was no heat, but all of the windows were foggy. They also noticed a few of the chrome thingies (steam vents) were missing from the free standing cast iron radiators. They eventually found the steam vents, they were imbedded in the wall, some as far as five feet away! Could you imagine sleeping with your head on the pillow two feet away from the radiator and witnessing a vent shooting out of a radiator, then filling the room with live steam? Talk about a nightmare, thank god they were not home.
When we arrived Monday morning we met with the insurance adjuster at the site. Together, we summarized that the boiler built excessive pressure, did not pop the relief valve and built enough pressure to rip the threads off the brass vents. We learned the pressure control failed to open the burner circuit. It could have been a clogged pigtail I honestly don't remember. Oh, and the boiler let go too from the high pressure. Monday afternoon we started installing the new boiler.
worked on boilers up to around 400hp and I always respected burner and boilers. I was only really scared one time. Maybe 2018 or 2019 the last year I worked my boss sent me to look at a Burnham steel boiler about 2,500,000 input with a Webster (I think) gas burner and the complaint was the burner was rumbling. This was about 3:pm.
Low pressure steam that they ran at 12psi for process. Burner was full mod. I had never worked on that boiler before so I looked around a bit. Manual reset limit, Modulating control and an operating control. Burner was sitting at 11 psi on the gauge and modulating. I went around the back of the boiler and started setting up my combustion tester. Took 3-4 min. After that i walked around the front and happened to see the guage now reading 25psi. Freaked me out.
I laughed and thought " bad gauge". But the little guy in my head said "shut the burner off". So I did and went to get a gauge in my truck. Came in and screwed the gauge into a spare tap and it was 25 psi. I left it shut off and searched for the building maintenance to tell him we had an issue.
They were still running process so I had to keep it running and baby sit it.
Finally got the ok to shut it down. I tried lifting the 15 psi safety valve and it was frozen shut. I broke it loose using a pipe for a lever. Removed the pressure controls and both pigtails were completly plugged shut (steel pigtails) Supply houses were closed by then and I didn't have any pigtails so I put the controls back in with 1/4" nipples.
Ran the boiler and the controls worked ok. Safety valve leaked a bit with the steam up but it was free so I new it would work.
Went back the next morning with a new safety valve, new brass pigtails made sure everything worked and made sure the control pipes were all clear and test the low water and pump controls.
Stll freakes me out when I think about it.
In order to be rated for x pressure, doesn't the failure point have to be several times that? I mean if I were standing there you wouldn't be able to convince me of that, but in reality it wasn't in danger of bursting at that pressure. If the runaway control had continued it could have.
Probably also didn't just happen the day you were there…
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
