steam cast-iron radiator issue
spaceship904
hello experts.
I have a single-pipe steam radiator system. The cast-iron convector on the second floor makes a noise similar to running water while the system is operating.
What could be causing this noise? Do you think the issue is with the convector itself, or could it be coming from the piping?
Audio uploaded here:
Sagged piping or maybe the valve is partially closed or defective. Steam maybe pushing through a puddle of condensate causing the noise. Does the convector heat sufficiently ?
One Pipe System0
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
