Dip Tube Replacement on Richardson
rohan_1794
rohan_1794 Posts: 26
edited November 14 in Strictly Steam
Hello,
I took apart a radiator which was not getting heat. I wanted to be sure the inlet was getting hot while it was not connected (it did). Then I removed the union or whatever it's call on the radiator outlet. According to the history books, these types of systems should have a dip tube to facilitate air and water condensate back to the return.
See attached. Where can I find a replacement dip tube and black ball that supports the trap in the photos provided.
    mattmia2 Posts: 18,416
    as long as you're controlling the pressure at the boiler to below around 8 oz/in^2 and you have the metering valve on the radiator you can probably leave the guts out of the return elbow.
  • @mattmia2, What's a metering valve? You mean the valve that opens and shuts down the steam supply? I heard of orifice a lot on this site, not sure what that is either.
    Steamhead Posts: 19,018
    @rohan_1794 , that's a later version that does not have the dip tube. The water seal is internal.
    Semi-retired
  • @Steamhead whitepages or any documentation on this new type?
    i'm not sure how the richardson valves work, if they have an orifice or a metering design, but the radiator valve on vapor systems is one way or another set up so it can only open to a precise size at most so it can't allow more steam than the radiator can condense in to the radiator if the pressure is kept low.
  • rohan_1794
    edited November 14
    @mattmia2 ah I see, thanks for that explanation. Unfortunately this house has gone through multiple owners and each has done their own Jerry-rigging. The radiator now is not using that type of inlet valve but something similar to the below.
    you likely will have to put orifice plates in the union for the valve. or put steam traps on the radiators without vapor valves
