Lochinvar Noble NKC-199 leak at pump connection
Hello all. What type of gasket does the grundfoss pump connections use. There is a leak on the inlet side side of the pump right at the threads. I’ve tightened the brass nut but it still leaks.
It's probably a flat, fiber gasket.
If you don't have a replacement handy, remove it and if it's in decent shape, coat it with a thin layer of teflon dope and replace it. Also check the mating surfaces of the pump and opposing flange to make sure they're smooth.
Two btu per sq ft for degree difference for a slab1 -
most likely a fiber washer They are a compression set material and not really reusable once they are compressed.
In a bind you could remove, dry and try a thin pipe dope coating
That looks like a composite body circulator so you don’t want to crank too hard on it
That also looks like the 1” size G thread I have used rubber water meter gaskets as a replacement. Find them at plumbing and Ace hardware
Or get a piece of gasket material from an auto part and use an Exacto knife to cut a new gasket. They have Fel-Pro fiber, or some red rubber material
Living the hydronic dream2
- 16.2K Strictly Steam
- 52 Job Opportunities
