Old compression tank into two port buffer
After I removed the old head banger gravity piping, I had this compression tank left over and it felt wrong to scrap it.
I've been meaning to do something with it and finally got it installed as a buffer on my A2WHP. It is running as a two port series buffer (volumizer) on the primary loop essentially adding a bit of extra heat capacity to it. I ended up welding a port to the top of the tank to allow me to bleed the trapped air.
It works pretty well for that, about halved the cycles during the shoulder season from about 2 cycles/hour to one. Hard to say if it makes a difference in COP, energy use around this time is too low, but definitely not hurting things as there is no mixing.
Brand:AnvilSKU:0318912640
data:image/svg+xml,%3C?xml%20version=%271.0%27%20encoding=%27utf-8%27?%3E%20%3C!--%20Generator:%20Adobe%20Illustrator%2023.1.1,%20SVG%20Export%20Plug-In%20.%20SVG%20Version:%206.00%20Build%200)%20--%3E%20%3Csvg%20version=%271.1%27%20id=%27No-RB%27%20xmlns=%27http://www.w3.org/2000/svg%27%20xmlns:xlink=%27http://www.w3.org/1999/xlink%27%20x=%270px%27%20y=%270px%27%20viewBox=%270%200%20100%20100%27%20enable-background=%27new%200%200%20100%20100%27%20xml:space=%27preserve%27%3E%20%3Cpath%20fill=%27%23CECECE%27%20d=%27M79.44,0.95H20.56C9.78,0.95,0.95,9.78,0.95,20.56v58.87c0,10.79,8.82,19.61,19.61,19.61h58.87%20c10.79,0,19.61-8.83,19.61-19.61V20.56C99.05,9.78,90.22,0.95,79.44,0.95z%20M65.38,58.24l9.38,29.58L49.69,69.78L24.5,87.82%20l9.34-29.6L8.8,39.6l30.73-0.17c0,0,6.98-19.61,10-28.93c0.54,1.36,9.88,29.1,9.88,29.1H91.2L65.38,58.24z%27/%3E%20%3C/svg%3EIf you want some mixing you could weld another tap on top and make it larger than the pipe you're using. Use a double tapped bushing so you would have a pipe inside the tank extended to the bottom
1-1/2" x 1" x 1" Black Double Tapped Tank Bushing, Class 150, 031891264004 Supply House.
Don't know where that crazy image came from.
good idea on the compression tank repurpose. Do it run chilled water in the summer also?
Living the hydronic dream0
