One floor loop not heating
bdohrn
bdohrn Posts: 1
edited 5:15AM in Radiant Heating
One loop of my hydronic floor heat is not warming up at present. I tried to purge the zone but when I attached the garden hoses to the webstone purge valve (having closed the main valves to isolate the zone) nothing moved. Per the designer of this system’s instructions for initial filling, I closed two of the flow meters and opened two including te problematic one. No water came out of the return…. I’m not sure if the hose I used should have been bigger so as to make more pressure?
Any thoughts on other reasons that the loop might be non responsive? The others are working….
    hot_rod Posts: 28,582
    look like only one of the white actuators is open in that pic. The top pops out with a green ring. How are you opening the others?
    The ball valve on the pressure bypass needs to be closed when purging also.
