Vitodens heating schedule
I have a Vitodens 200b2ha. The other day I changed the heating schedule from a Su-Sa schedule where all 7 days are the same to having each day on its own schedule. I woke up this morning and the pumps aren't running and it's 40 degrees outside. I removed the individual day schedules and tried to go back to the all 7 on one schedule but they didn't kick on after that change. I noticed that when selecting the times for operation, it used to read "standard" after the time. Once I switched it to individual days it now reads "normal". What am I missing here?
  • GGross
    GGross Posts: 2,111
    First I am assuming here because you never said it, the house is below temp. The boiler never turns on and the thermostat is definitely calling for heat? house is undertemp? If your house is at temp and thermostats are not calling then there is no problem
    not sure about "standard" and "normal" they would have 2 schedule settings, standard and setback but i dont recall where it reads that. so first step is to make sure you are not in a "setback" then make sure your boilers clock is reading correctly. if you set a time as a setback or whatever and the clock is wrong it will decrease temp at the wrong time. Then confirm that all your zone pumps are actually controlled via the boiler, often the zone pumps will have an external 3rd party control. its possible you have an unrelated problem that happened at the same time as changing the schedule. IMO I would rather an owner take time to properly set their ODR than to set a bunch of setbacks into the schedule. Allow the boiler to do its thing at the lowest temp required.
