Bell and Gossett-NRF-25
I had a severe case of fumble fingers today and I lost the machine screw for the wiring box for both new circulator cover and the old one.
Would any of you know what size the machine screw is so I can go to my local hardware store and buy several of them ? A magnetic tip Philips screwdriver is on the list too.
I have used 1/4" Drive #10 sheet metal screws in a pinch. But you should dull the sharp point so it doesn't pierce any wire insulation. but I believe it is a #6-32 the same as a outlet or switch cover on your wall.
That is what junk drawers in your workshop are for, different sizes of screws!
It is probably either a 6-32 or 8-32. Hardware store. Don't you have a junk drawer with some old stuff.
Thanks much folks, Now I am saddled with a back flow preventer that is seized shut, it is always something with me.
No, do not have an official junk drawer yet, but a big rolling workbench with lots of drawers is in the works.
Then you should have a coffee can or at least an old cookie tin. Your grandparents didn't live thru the depression?!? … or you would have inherited some of those full of screws. I remember the one that was full of buttons of all shapes and sizes. Mom always had just the right button when you lost one in the school yard.
I wish, my grandparents lived in Greece, and emmigrated after the first and second world wars were over. and most of southern Greece was turned into a wasteland by the Germans by 1945.
My junk drawer is in my kitchen, living room and bed room. :)
When I was working, I always had a bowl by the door when I came home I emptied my pockets. Wire nuts, screws and everything else ended up in the bowl. When truck stock got low I would know where to look.
Your wife fed you like the dog you are? From a bowl? This might be TMI.
