Is this old Hoffman 9A serviceable?
Hi All, This was completely clogged with gunk. I can't seem to remove the inside cage unit. Is this serviceable??
    it probably unscrews if you put a wrench on the hex on the cage unit.
    kacrejamReturnsMad Dog_2
    Steamhead Posts: 19,007
    And if the insides need replacing, you can get kits from Barnes & Jones or Tunstall. No need to replace the entire trap.
    Semi-retired
    Mad Dog_2
  • OK, i tried unscrewing it with no luck. did not want to break anything. But will try again.
