Rules on building a manifold, vent connector
GW
GW Posts: 5,269
I don’t know anything about tapping into vent connectors, it just seems silly to have a bunch of large tees stacked one after the other. But if that’s how it has to be, I am fine with that.
Years ago, somebody tapped into this 9 inch.
Can I do the same general thing? What are the guidelines. I’ve got four small boilers, 4 inch diameter coming off each one.
The traditional water heaters are going away, I will indirect water heaters coming off the new boilers.
Certainly somebody’s gonna ask me about chimney size, the boilers will be 60 K each, the chimney is about 30 feet high.
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • GW
    GW Posts: 5,269
    I also should’ve typed, the net BTU is going down, that’s how I was able to get three extra meter bars from the gas company
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
