mattress radiator
@Long Beach Ed I'm just really curious about the outcome if any, of the mattress radiator you've been working on. Any results?
  • Haven't done anything with it yet.
    I'm thinking that first I will try to remove the failed caulking and replace it with epoxy or red silicone.
    If that doesn't work, I'll probably remove the bolts, soaking them with Kroil and grinding flats on the threaded ends to get them turning. They appear to be in good condition. If they don't turn or can possibly be some sort of carriage bolt, I'll grind the heads.
    I will let you know.
