Steam Rating
How is Lbs. steam/hr. converted to BTU/hr.?
    mattmia2 Posts: 18,254
    It will depend on the pressure of the steam because higher pressure steam will be at a higher temp.
    109A_5 Posts: 4,628
    EBEBRATT-Ed Posts: 21,192
    edited September 10
    If it is low pressure steam under 15 psi use 970 btu/lb of steam. Everyone rounds it off to 1000btu/lb which is close enough.
    Other than that look for a steam chart on the internet you don't have to calculate anything. It will give you the BTU/lb at different pressures. I found one see the attached
    Use the latent heat column. The change of state is the useable heat
