"Frozen" gate valves
To disconnect the lower one, and to avoid damaging that partition fitting, the partition fitting should be braced by a wrench while the hex nut is being wrenched on, but why does the partition fitting not provide a gripping area for a pipe wrench?
I’m not sure they designed for this type of repair
The valve you want to work on is not part if that meter yoke assembly
So the letter on one of the handles is "Ford".
The swivel cup should be part of the interesting valve, not part of the isolation fitting. But there are no hex part on the fitting to match the swivel cups, so I'm puzzled how this was assembled initially
the meter yoke itself is all preassembled. You can buy various valve types to add on to the yoke, from Ford.
Then the installing plumber added that gate valve, and connections on the other end to the building supply line. So it is just an assembly of various Ford components.
This looks like the valve you have, swivel nut with EPDM washer on one end, pipe thread on the other. All these parts and info are at the www.fordmeterbox.com website
Regardless of what type or quality of valve you buy, unless they get used, exercised from time to time, the minerals in the water will cause them to stick in one position.
Those Ford valves are just a tapered brass plug inside the brass body, a fairly simplistic design.
As brass ages it tends to get brittle, so those top levers can shear off easily.
I don’t see a lot of need for those valves, just replace the gate valve and leave them alone. If you start twisting and wrenching on the yoke or valves, you may cause damage.
Contact the water supplier, maybe they would supply a new assembly. You will need to somehow shut off the water supply to do any work on this, so you need to involve whoever supplies the water to the building.
Once the water is off, this would be a simple repair job for an experienced plumber, just a few threaded joints.
Living the hydronic dream1 -
It took a plumber only 30 minutes to replace it with a ball valve. He was able to bend the incoming copper tubing in one hand.
The assembly below was recommended by Ford, but the plumbers do not agree with that approach.
a sewer line directly under potable water?
The water pipe is about 1ft above the sewer pipe. The sewer pipe is visible in the photo because the plumber removed the soils when replacing the valve. He put back the soils after the installation was done.
Oh, its a "soil" pipe then.
There is not another shut off valve (curb stop) before this valve. And the plumber said freezing is not good for aged copper tubing. So he opened the sewer trap, applied some pipe dope on the female threads of the new valve, disconnected the old valve, then quickly fitted the new valve that stopped the water. No time to wrap teflon and sealant on the male threads. I believe it is the common practice. But the running water would simply flush away most of the pipe dope before the new valve could get fitted in position.
Does this approach affect a lasting water tight seal?
In his first visit, I mentioned aged tubing will be harder and brittle, maybe he was just accommodating my concerns.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
