AO Smith HP split water heater
EBEBRATT-Ed
Member Posts: 20,493
Surprised to see they are using CO2 as the refrigerant. I guess it is good for low outdoor air temp operation
R-744 refrigerant should be less expensive for politicians, because they produce so much hot air every time they exhale. In most cases, they could probably recover more than enough CO₂ to operate the equipment — with plenty left over for the next campaign speech.
1
- 87.7K THE MAIN WALL
- 128 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
