Webinar: New opportunities with air-to-water heat pumps and dual fuel systems
Thank you to Weil-McLain for being a longtime supporter of Heating Help and for their commitment to industry education. Click here to learn more about their new webinar series.
ECO Hybrid Webinar Series
Learn how air-to-water heat pumps and dual fuel systems are expanding options for hydronic heating. This webinar series explores how changing customer needs and evolving regulations are creating new opportunities for air-to-water heat pumps in residential hydronic applications. Attendees will gain a clear understanding of where these systems fit today and how they can support comfort and flexibility for a wide range of projects.
Part 1 - May 21, 11:00-11:45am CT
Part 2 - May 28, 11:00-11:45am CT
Forum Moderator
Weil McLain is getting into the refrigerant/compressor business again? How long will this idea last?
@EdTheHeaterMan we installed all of the Weil McLain product you showed, except the hot air furnace. You forgot to mention the hwbb, AHE wall hung boilers, VHE condensing boilers, ten different indirect tank styles they rebranded, outdoor reset panels, etc.
Thank you Erin and Andrew for the heads up.
I remember working on some old 3 ton R-22 condensing units and If I remember right they were International AC Company owned by Weil McLain. They must have been 1960s-70s units as I saw them in 86' and they were tired.
You wont believe this but I liked the QB. when someone switched to gas, I put a gas gun in a WGO and removed the QB and took it back to the shop and rebuilt it so it would be ready for a customer that needed an new burner that may not have a lot of disposable income (if you know what I mean). You will never guess where it ended up when my Riello was acting up one cold night 15 years ago.
That is my boiler room in NJ. My son lives there now. and the QB is still pluggin' away
