Solar panel wiring
skyline137
skyline137 Posts: 85
I have a 15 year old 9.8kw system with 2 arrays and 2 inverters. 1 array is on racks tilted towards the South. For the last few years I’ve been picking up the plastic ties around my house. The ties are brittle and falling off and need replacing and wiring needs to be checked. Does anyone know of a solar contractor in Bergen County NJ .
    EdTheHeaterMan Posts: 12,857
    edited April 16
    Just look up "electrician" in your area (I would say "In the Yellow Pages" but that doesn't work anymore) and read their info. Someone does solar in your area, I'm sure.
  • skyline137
    I’ve called a few of the solar companies including the one which sold me this system 14 years ago. They don’t return my calls. It seems all they are interested in is selling new systems. I would much rather deal with a small owner if they even exist. Even Angi didn’t call me back.
    hot_rod Posts: 28,528
    i would think any electrician could check the wires and replace ties? I find the local small contractors on the newspaper online marketplace, FB marketplace, etc
  • skyline137
    I am waiting for response from a company that does “maintenance on solar panels.” I’m also getting some intermittent noises from 1 of my 2 inverters. Eventually I’ll get a response.
    109A_5 Posts: 4,617
    Be advised there are different grades of cable ties. They will last longer for your application. I would also install more than actually needed.
    Larry Weingarten
    EBEBRATT-Ed Posts: 21,169
    Not to throw a wrench in things but if I am not mistaken ty straps now need to be listed. Of course since this is existing if probably doesn't matter.
  • skyline137
    The cable ties used to secure the wiring on my 47 x 200 watt panel, $70,000, 15 year old solar system now snap like dried spaghetti. I’ve picked up about 25 or thirty off the ground probably many more on the roof. Even with the Federal and State incentives and SREC’s I will be lucky if I break even. My cost after government incentives to date is about 35k, I should have put that 35k in my 401k. Not to mention when I need a new roof the cost to remove and replace the panels will be about $250 per panel. The panels will be 25 years old then and will probably need replacement too!
    kcopp
  • skyline137
    edited April 20
    I got a quote of $$$ to inspect system and reattach wiring. I accepted that, hopefully that’s all they find.
  • @skyline137 Just a quick reminder that we don't discuss job quotes/pricing on here. I edited it out in your post above. Thanks!
    Forum Moderator
