Burnham Alliance Indirect Tank Maintenance
Slowhand63
What are the maintenance requirements for a hydrastone-lined Alliance indirect tank? I haven’t come across anything on line.
i think it is a Vaughn brand tank. They have some info here. Is it a top or side coil?
Flushing the tank once a year, and test the pressure relief valve year as per the manufacturer.
This is for the top coil model. Maintenance should be the same.
Living the hydronic dream0
