Pilot light
My neighbor has a gas fired cast iron boiler with a pilot light. Should he remove the pilot light and install an electronic ignition?
    mattmia2 Posts: 18,233
    no. it will cost you far more to do that than you'll ever burn with the pilot burner, unless there is some other circumstance like no one will be able to re-light the pilot if it were to go out or something like that.
    Bob_115
    HVACNUT Posts: 7,746
    He should do whatever his wife tells him to do.
    4GenPlumberBob_115
    109A_5 Posts: 4,617
    I also say No. Thermocouples are a very inexpensive maintenance item. To do the change you may also have to replace the Gas valve. Really no benefit with doing the conversion.
    kcoppBob_115
