Taco 007e failed
brians12373
brians12373 Member Posts: 1
hello. Ilwas my Taco007e installation done incorrectly which could have contributed to the failure. The manual says to install at the 9oclick position.
  • HydronicMike
    HydronicMike Member Posts: 345
    A) Are you sure it failed?
    B) It’s installed in an acceptable manner.
    bjohnhy
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,593
    Could be air bound
    bjohnhy
    109A_5 Member Posts: 4,025
    I Believe these are two different things. Your motor or maybe more specifically the motor's shaft is horizontal.
    The 9 o'clock is for best viewing orientation of the Junction box.
    jesmed1
    hot_rod Member Posts: 27,468
    there seems to be some issues with the molex plugs failing, check that, and return gor the upgraded version
  • SuperTech
    SuperTech Member Posts: 2,661
    That's the correct way to install a 007e on an Energy Kinetics boiler. I believe they come from the factory in that position. Every EK-1F I have worked on has the circulator installed in an identical location.
    szwedjRobertw
  • Joe Mattiello
    Joe Mattiello Member Posts: 751
    edited March 11
    what’s the date code? I suggest contacting Taco Tech support at 401-942-8000. They can help you trouble shoot
    Joe Mattiello
    Taco Comfort Solutions
