Boiler Gas Train Preventive Maintenance – What Most Techs Miss
This weeks video talks about an often ignored part of a boiler system, the gas train. It covers from the gas piping to the burner
Boiler Lessons
Hi, I am confused , just had new Burnham steam master max installed in 2 floor townhouse in Brooklyn. Every plumber I have talked to says ' Yea u should open the drain and drain a a gallon or two every week. maintenance, moreso if it comes out brownish to start' But on Page 3 of their manual it states DO NOT CONTINUALLY ADD FRESH WATER YOU WILL SEVERELY DAMAGE BOILER. I understand draining water means replacing water, so what is going on with this? Thanks for any help.
If you have a float type low water cutout you need to blow down the low water cuttout ever week to couple weeks. If it is a probe type low water cutout you should not periodically drain water from the boiler.
Hi Ray, You cover a lot of ground in this teaching. Nice! 🙏
Yours, Larry
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
