Decorative/art Panel radiator
Simply Rad
Simply Rad Member Posts: 205
Hi all
I have a legacy home with an art studio. The "inspiration area" is where the easel will be placed and is a bump out of all north facing glass. I have low temp radiant floor heating as first stage. I am looking for a very decorative/art hydronic radiator for the second stage. I remember in the past a company called Jaga but there website does not show the art radiators I remember from the past. Any other manufacturers?
Regards Jeffrey
Jeffrey Campbell
  • GGross
    GGross Member Posts: 1,834
    Runtal has some neat stuff and they dabble in custom radiators. This "hot spring" on their commercial lineup always intrigued me
    https://runtalnorthamerica.com/commercial-h-hot-spring/
    you could also look into making your own custom radiator. I know @hot_rod had the "hot dog" radiator at one point that was pretty awesome
    mattmia2 Member Posts: 16,376
    castrads has some decorative stuff too. there might be fancy stuff that is salvaged that is no longer available new too. what are you looking for?
    GGross
  • Simply Rad
    GGross
    Thanks for the Runtal link. I did not realize the commercial options. I am not sure what the owners are looking for just wanted to give them some options. I will have to get them approved by the interior desecrector🤣
    Jeffrey Campbell
    delcrossv
  • Big Ed_4
    Big Ed_4 Member Posts: 3,497
    You can heat any mass to make a radiator .. Heat up a sculptor , column or wall .
    you can fill a concrete or plaster sculpture with pex tubing and make it a radiator. Didn't @hot_rod build a cow radiator this way?
    hot_rod Member Posts: 27,266
    I don't see the real custom ones at Jaga anymore? Just the knockonwood line.
    Other names
    https://architizer.com/blog/practice/materials/winter-is-coming-16-designer-radiators/
    Screenshot 2026-02-24 at 3.41.58 PM.png Screenshot 2026-02-24 at 3.41.35 PM.png Screenshot 2026-02-24 at 3.41.11 PM.png Screenshot 2026-02-24 at 3.40.58 PM.png Screenshot 2026-02-24 at 3.40.25 PM.png Screenshot 2026-02-24 at 3.39.58 PM.png Screenshot 2026-02-24 at 3.39.30 PM.png
    Big Ed_4
