Do we know a hydronic pro in Milwaukee, WI?
I am looking to replace an old hot water boiler this summer.  Surprisingly, there are no HH Pros listed for my area on the “Find a Heating Contractor” page. Does the collective Wall have any suggestions for a pro in the Milwaukee area?
Thank you very much for your attention!
Trying to keep Bernie burning!
    EBEBRATT-Ed Member Posts: 20,085
    Don't know anyone in that area. Is their a lot of HW heat in your area? You could probably check with some of the plumbing/heating supply houses for recommendations.
    Others will comment.
    Alan (California Radiant) ForbesBernie_the_Brewer
  • Bernie_the_Brewer
    Bernie_the_Brewer Member Posts: 33
    Yes, there is a lot of hot water and steam heat, at least on the older side of town where I live.
    As for supply houses, interesting idea! I am only seeing the big names of Furguson, Grainger, and also Johnstone Supply. This is the kind of place you had in mind, right? I guess I could pop in and chat up the clerk, if I get the right sort of person.
