Looking for Weil & Mclain Recessed radiators
Nick7887
Member Posts: 5
Have some of these and need more anyone have any sources? I can't find anywhere.
There are recessed rads available. Wether they would match what you have is a different matter0
I think we might have a couple- not the exact model but close enough. Where are you located?All Steamed Up, Inc.
Consulting1 -
New Hampshire, please send pictures to rowing0307@outlook.com0
I have a house full of the exact same, I'm considering converting to hot water.
Are these tube type? or column?
They're beautifully recessed and its obvious it was state of the art in 38' and really can't imagine replacing.
just not very efficient
Check out Burnham SunRad radiators ..
the only thing that isn't efficient about them is that the wall doesn't usually get insulated behind it.
Why are you considering converting to hot-water? Is the present system steam, is there a problem with it?
Consulting1
- 117 Geothermal
